Hello.
I have a machine running Jira (port 8080) and confluence (port 8090).
I am trying to install another Jira (lets say Jira2) in the same machine, but I've changed the port to 9080 when I run the installation.
When I finish intalling Jira2, I try to open it in the browser but the Service is not launched.
In fact when I look into my services I only get 1 "Atlassian Jira", which is running but this is my first Jira instance.
I looked into the url: https://confluence.atlassian.com/jira/running-multiple-instances-of-jira-on-one-machine-222200571.html
AND i CHECKED THIS:
When I installed Jira2 I choose the run it as a Service. What am I doing wrong, can you help? How can I run this 2 Jira in the same machine?
Probably the installer attempted to run both the JIRA's with the same name (maybe a default in the installer) and the second one was not registered.
You can still add the second one as a service, as described at https://confluence.atlassian.com/adminjiraserver071/running-jira-applications-as-a-windows-service-802593173.html#RunningJIRAapplicationsasaWindowsservice-ManuallysettingupJIRAtorunasaservice.
Just make sure you use a different name this time.
When I try to do:
service.bat install JIRA2
I get error (Failed installing 'JIRAServiceDesk210218101116' service).
How can I fix this?
JIRA or JIRA2 is just the display name. Try finding the name of the current service (JIRA) as described at https://confluence.atlassian.com/adminjiraserver071/running-jira-applications-as-a-windows-service-802593173.html?_ga=2.241463298.1076185001.1519094384-1760194658.1485552941#RunningJIRAapplicationsasaWindowsservice-Locatingthenameofaservice.
You can then rename that service before registering JIRA2. You will find online docs on renaming a service.
Assuming you have configured the new JIRA to run on separate ports from the original 8080 you can following the service setup steps here to manually add an additional service.
Done that, When I run "
service.bat install JIRA" I got this error:
C:\Program Files\Atlassian\JIRA2\bin>service.bat install JIRA2
Installing the service 'JIRAServiceDesk210218101116' ...
Using CATALINA_HOME: "C:\Program Files\Atlassian\JIRA2"
Using CATALINA_BASE: "C:\Program Files\Atlassian\JIRA2"
Ignoring JAVA_HOME: "C:\Program Files\Java\jdk1.8.0_161"
Using JRE_HOME: "C:\Program Files\Java\jre1.8.0_161"
Using JVM: "C:\Program Files\Java\jre1.8.0_161\bin\server\jvm.dll"
Now I checked and notice one thing: I went to /jira2/bin folder and run startup.bat and waited,,,
I went to browser and now it seems to be working...
So in the second installation it did not run as a service.
So, do I have to do it manually, for the second Jira?
