×HI Guys,
Need a urgent Help with apache, am lost with this from last 4 days and am mot able to figure out what mistake i have made
Scenario :- we have Jira server running on TOMCAT, and now what we want to do is to integrate it with apache over SSL, have configured apache & tomcat using proxy, & also itś geting diverted to apache Over SSL but dashboard is not getting displayed properly
attaching here with the Screen shot, Config file and error log, guys please help me out where i am going wrong .
(server.txt) (ssl-error.log)
It seems that your <Connector> entry in conf/server.xml entry is broken.
Here is what works for me:
- use the default server.xml file and uncomment the second <Connector> entry (the one with AJP)
- in your httpd.conf and httpd-ssl.conf, add
ProxyPass / ajp://localhost:8009/ ProxyPassReverse / ajp://localhost:8009/
This will probably also work with the http protocol instead ajp, to do that, use http://... instead of ajp:// and the 8080 port number.
Hi Dennis this is mine .conf file of apache
Which guide are you following? Also, the problem of the stylesheets not showing up might have to do with a wrongly configured base url, be sure that this is set to the new https address. Can you also provide your apache configuration file? Thanks!
This is the .conf file in Apache
LoadModule ssl_module modules/mod_ssl.so
Listen 443
<virtualhost *:443>
# ServerAdmin root@millenniumit.com
ServerName jiraup1-80.millenniumit.com
ErrorLog /var/log/httpd/ssl-error.log
LogLevel warn
CustomLog /var/log/httpd/ssl-access.log combined
ServerSignature On
SSLEngine On
SSLCertificateFile /etc/httpd/ssl.crt/millenniumit.com.crt
SSLCertificateKeyFile /etc/httpd/ssl.key/millenniumit.com.key
SSLCertificateChainFile /etc/httpd/ssl.crt/ca.crt
SSLProxyEngine on
<proxy *>
Allow from all
</proxy>
ProxyRequests Off
ProxyPreserveHost On
ProxyPass / http://localhost:8080/jirasup1-80
ProxyPassReverse / http://localhost:8080/jirasup1-80</em<>>
</virtualhost>
try
ProxyPass /jirasup1-80 http://localhost:8080/jirasup1-80 ProxyPassReverse /jirasup1-80 http://localhost:8080/jirasup1-80
if i use
ProxyPass
/jirasup1-80
http:
//localhost
:8080
/jirasup1-80
ProxyPassReverse
/jirasup1-80
http:
//localhost
:8080
/jirasup1-80
The requested URL /secure/Dashboard.jspa was not found on this server.
Both left and right path / url must be the same and must match the path from your base url in JIRA and also the path attribute from your server.xml which is not the case.
Just try the ajp configuration a try, it should work right away.
