I am trying to run Jira (port 8080) and Confluence (Port 8090) on a single server in AWS internal VPC network. The certificate is installed on the AWS Application load balancer.
The ALB setup is as follows:
Port 80 redirect to Port 443 (within the ALB)
Https Port 443 -> Target Group 80 (Apache to direct back to https)
Https Port 8080 - Target Group 8080
Https Port 8090 - Target Group 8090
The problem is that at times certain links within jira still gets pointed port 8080. Certain gadgets also dont load as well. Can you please advice.
When Gadgets name display incorrectly it is definitely a Certificate Issue.
Best,
Fadoua
