SIL: how to disabe elements checkbox
Denis Shestov
July 11, 2018
Hello! How i can disable any elements in checkbox field?
I have checkbox field with 10 elements.
In first condition if(...) i using lfAllowSelectOptions and allow 1,2,3,4,5 and 8 elements checkbox. next else if i planed used also lfAllowSelectOptions for allow elements 6 and 7.
But in experement i found out that lfAllowSelectOptions work with checkbox if it contains 1 (first element). Otherwise lfAllowSelectOptions is not work. With lfRestrictSelectOptions the same thing
Jonathan Muse {Appfire}
July 11, 2018
Hi Denis, I opened a support ticket for you regarding this issue.
Denis Shestov
July 11, 2018
Yeah. Thanks!
Ivan Tovbin
July 11, 2018
Could you show your code?
