SOLVED: Checkboxes on multiple columns in Jira
Roberto Arnetoli
September 23, 2017 edited
Hi ,
I am trying show checkboxes on multiple columns in the create and edit forms of an issue using a script I found in a older question, but I am still unable to make it work.
The script that I am using is
<script type="text/javascript">
(function($){
$(document).ready(function(){
$("input[name='customfield_10405']").parent().attr('style', 'float: left');
})(AJS.$);
</script>
and I am sure the customfield number is correct
Yet, I am unable to make it work.
Can anybody help?
I am using Jira Server v7.4.4
Thanks in advance
Roberto
7 votes
Roberto Arnetoli
FINALLY!!
this is the JS to be added to the customfield description to have checkboxes on multiple columns
<script language="javascript">
AJS.$(document).ready(function(){
Array.from(document.body.getElementsByClassName("checkbox")).forEach(function (cbox) {
if (cbox.getAttribute('name')=='customfield_10405') {
cbox.parentNode.style.cssFloat='left';
cbox.parentNode.style.width='20%';
</script>
Ramesh Krishnamoorthy November 13, 2017
Hi Robert, can you please clarify where exactly the script has to be pasted? And, what about the double quotes in the script? Will they create problems during script eval?
The above script is not working for me and it just gets added into a <p> tag in the page and doesn't get executed. Not sure what I am doing wrong.
Roberto Arnetoli
November 16, 2017 edited
You have to put it into the description of your custom field.
see screenshots in question as an example
Like Alena likes this
Sysad
Hi @Roberto Arnetoli
script works great on Jira and it looks as expected on create issue screen. However, do you have any idea how achive similar in the Jira service desk customer portal?
Like 2 people like this
Ivan Torres-Candelaria
@Sysad did you find a way to pass this to the portal? Thanks
dorin gez April 28, 2021
@Roberto Arnetoli Hey, the script is causing the screens that contain this field to jam. Even through the settings I can not access it. What am I doing wrong? Thanks
Steven Schouppe September 14, 2021
@Roberto Arnetoli Works great for me.
Bill Galvin
March 22, 2019
Can anyone tell me if this will work in Jira/Cloud?
TJ
November 11, 2019
Same for me.. does anyone knows how to make this work on Jira Cloud?
Hi! Any way to actually do this for the Customer Portal?
Laci
So, visually this works great... however, by putting this script in, I can no longer bulk edit this field. Thoughts on how to make that possible without removing the script? Thanks!
Roberto Arnetoli
September 24, 2017 edited
I have found that the following javascript or css applied to the create issue form source (using Fiddle) do exactly what I need:
var cbox = document.getElementsByClassName("checkbox");
for(var i = 0; i < cbox.length; i++) {
if (cbox.item(i).getAttribute('name')=='customfield_10405') {
cbox.item(i).style.cssFloat='left';
cbox.item(i).style.width='25%';
.checkbox[name=customfield_10405] {
float: left;
width: 25%;
However, when I try to apply it to the Jira customfield, it does not work :-(
This is what I am adding to the customfield description:
</script>
Any help on what to do?
thanks
Roberto Arnetoli
I found that adding the following JS to the custom field description (replacing the for loop) has an effect on the right customfield, However it is still not doing what I need - it is actually moving the tickbox to the right and making it bigger but still in 1 column (see below).
cbox.style.cssFloat='left';
cbox.style.width='50%';
</script>
