I want to write a sql query which shows me all Project Names, Start Date and End Date based on project sprint mapping..
Thank you in advance.
Hi Srinivas,
try the following query (10004 is the id of the sprint customfield)
SELECT p.pname as project, min(s."START_DATE"), max(s."END_DATE") FROM "jiraissue" i JOIN "customfieldvalue" cf ON cf.issue = i.id AND cf.customfield = 10004 JOIN "AO_60DB71_SPRINT" s ON s."ID" = cf.stringvalue::int JOIN "project" p ON p.id = i.project GROUP BY p.pname
Peter
Remember that this can give you many projects and sprints - sprints do not belong to projects, or vice-versa, it's a many:many relationship.
Thanks for the response. As per above query i don't have any custom field.
My requirement as fallows.
Project Id | Project Name | Start Date | End Date |
1 | A | 22/10/2015 | 22/10/2016 |
2 | B | 22/10/2015 | 22/08/2016 |
3 | C | 22/10/2015 | 22/10/2016 |
4 | D | 22/10/2015 | 22/10/2016 |
Start Date: Project first Sprint start date
End Date: Project end Sprint end date ( if sprint is not completed as per today date it should be empty)
Thank you.
You have a sprint custom field (which associates an issue with a sprint) created implicitly by JIRA software/JIRA agile - you will have to check its id manually and replace it in the query, as it is different for different JIRA instances. The above sql will return start and end dates as seconds since epoch - you will have to convert them to date manually, depending on the type of your db server
Help us plant more trees
