SQL join to show some native fileds along with some custom fields
Julio Mugabe
In the past, it was easy to write an sql join statement and show pkey from the jiraissue table along with the custom value from the customfieldvalue table because these tables were related. Right now it is a little harder because there is a new table called customfieldoption that stores the customfield values. This table is not directly related to the jiraissue table and make is hard to create a join or subquery to retrieve the desired data. Here is an example of data I want to pull from the jira database:
| key | CUSTOMFIELD1 | CUSTOMFIELD2 | CUSTOMFIELD2 |
| abc-102 | 14812 | new york | xyz |
Please send me an sql statement I would use to show the above data.
daniel santigosa January 21, 2013
It depends on customfield you want to display. Data you want to display can be in customfieldoption or customfieldvalue.
To show something like your example you need for example:
SELECT
    jiraissue.pkey,
    (select
            customfieldvalue.stringvalue AS NUMBR
        FROM
            customfieldvalue
        WHERE
            customfieldvalue.issue = jiraissue.id
                AND customfieldvalue.customfield = 'xxxx'),
    (select
            customfieldvalue.stringvalue AS CITY
        FROM
            customfieldvalue
        WHERE
                AND customfieldvalue.customfield = 'yyyy'),
    (select
            customfieldoption.customvalue AS LETTER
        FROM
            customfieldvalue,
            customfieldoption
        WHERE
                AND customfieldvalue.customfield = customfieldoption.customfield
                AND customfieldvalue.customfield = 'zzzz')
FROM
    jiraissue
THIS QUERY DISPLAY:
| key | CUSTOMFIELD1(xxxx) | CUSTOMFIELD2(yyyy) | CUSTOMFIELD2(zzzz) |
I hope this help you
Mehmet Kazgan
January 7, 2014
Daniel,
How could I get the following?:
customfield | Issue (with query1) | Issue (with query2)
customfield1| value for issue | value for the issue
customfield2| value for issue | value for the issue
Thanks.
mwarton
January 7, 2014
Hi Julius,
Not sure exactly what you are doing, but if you install the Intelligent Reports plugin you could load this data into a table in a Word file with no programming involved, and use your data for whichever purpose from there.
Hope it helps,
