SQL to export SSO SAML configuration?
Savvas Radevic February 19, 2024
Hi we would like to automate several SSO/SAML configuration, to export from and re-import to the SQL database (MySQL).
Do you know which data (tables/columns/values) to export to get the configuration for the Atlassian SSO plugin?
https://marketplace.atlassian.com/apps/1216096/sso-for-atlassian-server-and-data-center
Thank you.
Savvas Radevic February 19, 2024 edited
how to configure SSO / SAML through REST API and/or MySQL
quoting the Atlassian developer support:
https://confluence.atlassian.com/confkb/list-of-rest-apis-available-to-configure-sso-on-confluence-dc-1085188345.html
You may want to assess if you can use the available REST API endpoints for the activity you would like to conduct.
Although it mentions Confluence, these are valid for Jira as well.
Regarding on which database tables the configuration are stored, you may check the following SQL queries for Jira:
Generic configuration.
select pe.property_key,ps.*,pt.*
from propertyentry pe
left join propertystring ps on pe.id = ps.id
left join propertytext pt on pe.id = pt.id
where pe.property_key like 'com.atlassian.plugins.authentication%';
IdP configuration.
select *
from "AO_ED669C_IDP_CONFIG";
Marc - Devoteam
February 19, 2024
Hi @Savvas Radevic
Best option is to reach out to the developer of the app.
They will know where the information is stored in your DB in relation to the configuration.
As it's an app from Atlassian, reach out via Atlassian Support
