I am trying to set up SSL and I am having some trouble really understanding how to get the cert and cert path into a Keystore that the Jira application can read. We have our own PKI and I will need to set up the store so that it has our root, sub and cert.
B
Hi Burton,
As a guide you could check out in Running JIRA over SSL or HTTPS documentation.
Also, are you using proxy in front of JIRA? I mean Apache, IIS.
Would you please explain a little bit more what is the main problem you're facing?
Have you configured SSL as described above and got some error? If so which error was it?
I hope it helps.
Cheers.
Hi, I have read the guide. Where my confusion starts is where is the keystore I should be using? Also, we are using our own PKI so I need to add my own root ca and sub ca to the trusted roots. I am not using an apache reverse proxy.
Thanks for the feedback!
Burton
Hi Burton,
Once you have already created a certificate, basically you'll need to:
$JAVA_HOME/jre/bin/keytool -import -alias YourCertificateName -file YourCertificateName.cert -keystore /path/to/your/keystore
<Connector
port="8443" maxThreads="200"
scheme="https" secure="true" SSLEnabled="true"
keystoreFile="/path/to/your/keystore" keystorePass="CertificatePassword"
clientAuth="false" sslProtocol="TLS"/>
-Djavax.net.ssl.trustStore=/path/to/your/keystore -Djavax.net.ssl.trustStorePassword="CertificatePassword"
Restart JIRA and check if SSL is working.
I hope it helps.
Kind Regards
