I can't seem to find any samples about JQL in scripted field. If anyone knows let me know.
I would like to have a scripted field that displays information from a field from a JQL result set.
e.g. based on current issue's component, get the source repository information, captured in a separate jira project with additional component info (sort of lookup table for component)
To get data from a JQL query would be like this
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.jql.parser.JqlQueryParser;
import com.atlassian.jira.issue.search.SearchProvider;
import com.atlassian.jira.web.bean.PagerFilter;
def findIssues(String jqlQuery) {
def issueManager = ComponentAccessor.issueManager
def user = ComponentAccessor.jiraAuthenticationContext.user
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser.class)
def searchProvider = ComponentAccessor.getComponent(SearchProvider.class)
def query = jqlQueryParser.parseQuery(jqlQuery)
def results = searchProvider.search(query, user, PagerFilter.unlimitedFilter)
results.issues.collect
{ issue -> issueManager.getIssueObject(issue.id) }
Then you can use it like this
def issues = findIssues(jqlQuery)
