Screen refresh based on custom field change
Bart Jutte August 21, 2018
How can I trigger a screen refresh if a custom field is updated in JIRA?
Nir Haimov
August 21, 2018
where the customfield is updated from?
if it updated from inline edit or "edit" screen it should automatically refresh the page content
Dan Buica August 21, 2018
It is updated from the board screen.
Nir Haimov
August 21, 2018
can you please send a screenshot of the screen from where you do the update?
so it is done from the detail panel on the right. This displays some custom fields as well.
Nir Haimov
August 21, 2018
Yeah,
But from the detail panel on the right, it's the same as inline edit.
If you update a customfield from there, it is refreshing at the same moment automatically.
No need to manually trigger refresh as @Dan Buica ask
We need it to trigger a board refresh.
Nir Haimov
August 21, 2018
OK, i don't see a reason to do it, but in any case, there is no way (that i know of) to refresh only the board, you can refresh the entire page (like reload), and you can do it by inject JS (if you are using Jira server and not cloud).
Does it answer your needs?
Yes it does.
Thanks.
But how exactly do I detect the update event?
Nir Haimov
August 21, 2018 edited
JIRA.bind(JIRA.Events.INLINE_EDIT_SAVE_COMPLETE, function() {
location.reload();
Once the inline edit completed, this will reload your board page.
Dan Buica August 22, 2018
It works just fine for Jira Server. Thanks.
Is there any way to do this on cloud?
Nir Haimov
August 22, 2018
Where did you inject the JS in Jira server?
In cloud i think the only way to inject JS is from the announcement banner
I've injected it in the custom field's description.
Nir Haimov
August 22, 2018
OK,
In cloud you can't to that, the only solution in cloud was the "announcement banner" but i just remembered that they removed it from the new experienced Jira Cloud.
There is an open ticket to Atlassian about it, but till then, there is no way to inject JS, unless you create your own plugin for cloud to do what you want
Ok.
Thank you.
Nir Haimov
August 22, 2018
You are welcome.
Please mark my solution as the answer so this thread will be closed
YUVARAJ KUNDASI November 22, 2019
@Nir Haimov  What if the custom field is updated from REST API.  Is there is any other way to refresh the page so as to see the new custom field value.
Nir Haimov
November 24, 2019
Hi @YUVARAJ KUNDASI
Sorry but,
You can't do that from the REST API.
Like YUVARAJ KUNDASI likes this
Register Now
