hi team,
I have taken jira cloud free trial subscription and I am not able to see script field in my custom filed in jira settings.
I need to get value after some processing, which I will write in SIL but I am unable to add script field as it is not visible
Scripted fields are not available in Cloud. You would need to create a usual custom field and add a post function, in which you would update this field.
Thanks Alexey,
Attached are my sample report where
1. First I want to customize the status column
2. I need one additional column NO of open days which should calculate the issue date from current date.
3. I already have a field estimated production resolution which I want as ETA of resolution.
I want all these in my report by either script, rest API or anything.
please help on this.
Ruchi
Do you mean that you can do the UI part of these reports, but you need to get data from Jira somehow for these reports? If so, you can use Jira Rest Api to get all data and then process it and show this report.
