Script Fragments Create Constrained Issue dynamic project
//SEIBERT/MEDIA February 16, 2017
In the Create Constrained Issue fragment we must specify a project. Is it possible to set the project based on the contextIssue where the action is triggered from?
JamieA
February 21, 2017
You need a context provider. This makes additional variables available to the URL. There's a full example here: https://answers.atlassian.com/questions/43888344
Phill Fox
The constraint in this instance is the project in which the new issue must be raised. There is a way to script the creation without it being in a set project. But this requires a slightly different approach to the Create Constrained Issue approach.
Although if the number of projects is small you can just create a constrained issue creation for each project.
You can contact me direct at pfox(at)adaptavist.com
