In the Create Constrained Issue fragment we must specify a project. Is it possible to set the project based on the contextIssue where the action is triggered from?
You have two options:
1) Answer from Adaptavist to my same question
2) Create the constrained issue and set a project (you have to do this). Then add a behavior that sets the project to the current project when triggered.
I have successfully done both of these, but ultimately went with option 2 as all our workflows and base configuration are the same for all projects so I did not have to worry about a project not having the correct issue type.
Jodi
please send link again.
I don't think it's possible to filter the project list.
Help us plant more trees
