Script Registry showing zero after upgrading jira from version 6.1 to version 8.5.8
Dayanand
After upgrading jira from version 6.1 to version 8.5.8 Script Registry showing zero workflow, jobs, listeners used but where as before upgrade it was showing some workflow names when we run Script Registry
Fazila Ashraf
@Dayanand  , that is weird. Is this a production setup?
How did it behave in the lower environments?
Did you try to restart JIRA already?
Dayanand
Hi Fazila,
Thank you for your quick response.
Yes did below steps may help me to get Script Registry may show values.
1. restarted jira no luck.
2. Performed re-indexing still same issue it is not showing any out for Script Registry on upgraded instance.
Note: Is anybody know how this Script Registry works internally so that i can debug this further
Fazila Ashraf
@Dayanand ,
Are the scripts actually there and working properly?
Is it only a problem with the script registry?
If you are looking for internal working of the functionality, raising a support ticket with scriptrunner is the right direction
Dayanand
Thank you Fazila contacting  scriptrunner support.
Like • Fazila Ashraf likes this
Dayanand
Shows none used by script runner for upgraded UAT jira v8.5.8.PNG shows scripts list in prod jira v6.1.PNG Attached screenshot after running script registry before the upgrade and after the upgrade.
Register today
