Script Runner Behaviours - Hide/Show based on checkbox selection
Dave Theodore [Coyote Creek Consulting]
I have the following checkbox field:
Existing Program or Campaign? ( customfield_10209 )
It has two checkboxes: Yes, No
If (and only if) the "Yes" checkbox is selected, I need the following field to appear on the screen:
Campaign or Program Name ( customfield_10208 )
My server side script:
def checkBox = getFieldById("customfield_10209")
def conditionA = getFieldById("customfield_10208")
conditionA.setHidden(true);
if (checkBox.getValue() == "Yes") {
    conditionA.setHidden(false);
JIRA Core version 7.1.9
Script Runner version 4.3.6
When creating an issue, the "Campaign or Program name" field always appears. If you tick the "No" checkbox, it goes away. If you untick the "No" checkbox it stays away. If you tick the "Yes" checkbox it appears.  I need to make it not appear initially and only when the "Yes" checkbox is ticked.
Any suggestions are appreciated.
JamieA
September 12, 2016
But to answer your question, it seems like for checkboxes the validatior is not firing when the form first loads, as it should.
To work around this you can use an initialiser to set it hidden at first, or just use the configuration options on the field in the behaviour.
Richard Duffy
@JamieA
Hi Jamie
I am trying to fix the same issue, the workaround of using the initialiser does work. However i dont want to use this as I have many projects using this screen scheme so therefore the hidden field is shown on there screens!
I would like to use the field configuration to make my custom field hidden and then use the behaviour to show it. But i cannot get this working.
For this example i have the field "Hidden Field" set to hidden in the field configuration. When i choose "SIT" for the field "Environment Name" it does not unhide "Hidden Field"
def cfENV = getFieldByName("Environment Name")
def cfHID = getFieldByName("Hidden Field")
def cfENVVAL = cfENV.getValue()
if (cfENVVAL == "SIT"){
cfHID.setHidden(false)
}else{
cfHID.setHidden(true)
ps- All this is on the create screen
Can you advise?
Richard Duffy
@JamieA
Do i need to look at the field configuration and the custom field config for it? If so how do i do that?
I got it working.  As Jamie suggested, I needed  to hide the field first with an "Initialiser Function,"
Marc Jason Mutuc
May 18, 2017
Please share your code. I'm trying to the the same but based on the component instead.
They don't want the "none" option, and I can't disable that globally. Checkboxes is an easy way to have only "Yes" and "No" and the plan is to use a workflow validator to ensure that only one is selected.
JamieA
September 12, 2016
or a single checkbox...
JamieA
September 12, 2016
Why don't you use radio buttons? Being able to tick both Yes and No doesn't make any sense.
Mark McCormack (Adaptavist)
September 9, 2016
Hi Dave,
Please try the following:
def checkBoxField = getFieldByName('Existing Program or Campaign')
// Get a pointer to the Start Date Field
def conditionField = getFieldByName('Campaign or Program Name')
// Get the Select List Field Value
def checkBoxFieldVal = checkBoxField.getValue()
// Hide Campaign or Program Name based on checked value
if (checkBoxFieldVal == "Yes"){
   conditionField.setHidden(false)
}else{
   conditionField.setHidden(true)
That works for me, so I hope it helps.
Please ensure you have the Campaign or Program Name field in the behaviour set as Optional/Writable/Shown too.
regards, Mark.
Thanks for the script, Mark.  Unfortunately, same behavior.  This is on a create screen, if that matters.  When I click the Create button, both fields are present. If I tick the "No" checkbox, the "Campaign or Program Name" field goes away. If I untick the "No" checkbox, it stays hidden. If I tick the "Yes" checkbox, it appears.
September 12, 2016
Hi Dave,
Do you have any javascript or any other Behaviours configured that may potentially clash?
Can you try adding log.warn("setting conditionField") to your logs and see if that helps you get to the bottom of it?
regards, Mark.
