Script Runner - How to Transition task to next status if assignee != Unassigned
TomS March 5, 2013
Using the Groovy Script Runner to transition tasks to the next status. Confirmed working in all cases with condition "issue.assignee != originalIssue.reporter". However the problem is that there are two use cases in our task workflow.
  1. Use Case 1: Ticket is not assigned to a production artist, default project assignee is "Unassigned" and the ticket waits for action at the Open status until it can be assigned.
  2. Use Case 2: Ticket is created and assigned to a user and is automatically transitioned to the next status
The condition "issue.assignee != originalIssue.reporter" only answers Use Case 2 above, not Use Case 1 since all tickets are transitioned to the next status, including Unassigned tasks.
How can I write the condition so that issues are transitioned only under the following circumstance. The issue assignee is NOT the reporter AND is NOT "Unassigned".
JamieA
March 6, 2013
have you tried:
issue.assignee && issue.assignee != originalIssue.reporter
TomS March 6, 2013
Thankyou Jamie, this worked perfectly.
Learn more
