Script Runner - Restrict creation of specific issue type for specific users/groups/project
fjodors
July 3, 2014
Hello
I am looking for ability to restrict creation of specific issue type for specific users/groups/project.
I found that the easiest solution is a Script runner validator in workflow "create transition"
So I need the condigition:
if
issueType="IssueType" && user who is creating this issue is member Of Role("Project Role") && project is "PROJECTKEY"
returns true, then issue could not be created.
1) issue type condition is
issue.issueTypeObject.name == 'Bug'
2)project role condition is
isUserMemberOfRole('Administrators')
3) I am not able to find condition for project. I tried
issue.getProjectObject().key == "ABCD-123", but it doesn't work.
Is there a possibility to find a project key? I need to merge these three conditions.
Thank you in advance,
Fyodor
Svante Gustafsson Björkegren
July 3, 2014
Hello Fyodor,
Use the following syntax to grab the project in your condition:
issue.projectObject.key == 'ABCD'
The complete condition would look something like:
issue.projectObject.key == 'ABCD' && isUserMemberOfRole('Administrators') && issue.issueTypeObject.name == 'Bug'
Hope this helped!
// Svante
July 3, 2014
btw: I re-tagged your question to more correct tags. Hope you don't mind :-)
fjodors
July 6, 2014
Hello Svante
Thank you for info.
I need to check three conditions, so it seems I need creat multi-level condition, e.g.
if(issue.issueTypeObject.name == 'Bug'){
if(issue.projectObject.key == 'ABCD'){
if(!isUserMemberOfRole('Administrators')){
invalidInputException = new InvalidInputException("Invalid condition!")
In all others situation issue can be created
Is it possible to put such exression in script runner validator?
regards,
Fyodor
Alex Gubar October 12, 2017 edited
import com.opensymphony.workflow.InvalidInputException
if(issue.projectObject.key == 'ProjectA'){
if(issue.issueType.name == 'Task'){
if(!isUserMemberOfRole('Manager')){
invalidInputException = new InvalidInputException("Task can create Manager only!")
But this is not work...
Rafael Fernandez Coelho November 13, 2020
hello,
i use cloud version, so i dont know if what i will say applies to your case.
since it is a validator, i believe it does not accept "if" (at least I could't use until now), it is only possible to use jira expressions or something like that.
but you dont need 3 if, because it will only permit the creation (or whatever you are validating) when all is true, right? so you can use all of them ia a single line joined by AND (&&)
something like this i believe
and thanks, i was looking for something that could validate if the user has some role in the project!
Register Now
