I have been trying to create a scripted field on a sub-task. This scripted field will display data from the parent issue. This field is a numeric value custom field
Parent Issue - Improvment
Custom Field - DBA Estimate (Numeric)
Sub-Task
Scripted field - Parent DBA Estimate
The script I've created isn't working correctly -
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.fields.CustomField;
def abc123 = issue.parentObject.getCustomFieldValue("DBA Estimate");
return abc123;
Here's the correct code:
import com.atlassian.jira.issue.Issue; import com.atlassian.jira.ComponentManager; import com.atlassian.jira.issue.CustomFieldManager; import com.atlassian.jira.issue.fields.CustomField; import com.atlassian.jira.component.ComponentAccessor; def field = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("DBA Estimate") def abc123 = issue.parentObject.getCustomFieldValue(field); return abc123;
Also make sure to set template : Number Field on the scripted field and also set the searcher to Number Searcher
Dear Borris,
Tried the same but getting below error response.
2020-10-09 10:35:49,734 ERROR [runner.ScriptFieldPreviewRunner]: ************************************************************************************* 2020-10-09 10:35:49,734 ERROR [runner.ScriptFieldPreviewRunner]: Script field preview failed for field that has not yet been created org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script32.groovy: 2: unable to resolve class com.atlassian.jira.ComponentManager @ line 2, column 1. import com.atlassian.jira.ComponentManager; ^ 1 error
what i am missing?
