After installation of Script Runner I have seen all 88 plugins are enabled.
We want to use in every case the functionality of Built-in-Scripts
Also we want to use the JQL function hasAttachments - this is all.
I believe I can deactivate many of the enabled plugins. Do anybody knows which one we don't need?
Juliane,
There's no need to disable the other modules of the add-on. If you are not using, they will not interact with your installation.
-- Pedro
I do not want that any customer can uses some stuff we don't want. Do you think this could be a problem?
