Script Runner aggregate function not working
swetha meti December 7, 2016
Whenever i fire the below query, i get the below error in JIRA.Could you pease assist.
project = "XXX " AND type = Story AND Sprint in (2276, 2244, 2152, 2162, 2200, 2435, 2255, 2318, 2222, 2233) AND  issueFunction in aggregateExpression("Story Points" ,"QAStoryPoints.sum()
image2016-12-7 17:45:15.png
But when i give the below query, its working. Both Story Points and QA Story points are Field Custom Fields
image2016-12-7 17:45:47.png
Jonny Carter
December 7, 2016
I noticed that there's a colon in your field name. Perhaps that is the issue? ScriptRunner simply isn't finding your field because you're not asking for it by its name.
Corrected the Field name by removing the colon and it works now.Thanks.
i did try putting a colon at the end of the field name, but its not helping.Below is the error.Should i edit the Field name and remove the colon for this issue to get resolved?
image2016-12-7 21:40:58.png
QA Story Points custom field is also a Number field.Attaching a screen shot.
image2016-12-7 20:18:41.png
image2016-12-7 20:20:18.png
Jonny Carter
December 7, 2016
They're both custom fields, but custom fields have types. What type of field is QA Story points?
If QA Story Points is a scripted field, then ScriptRunner will try to infer its type based on the searcher. JIRA Software's Story Points field is a Number field. What type is QASP?
