Script Runner installation questions
Joe
July 28, 2014
Hello.
I am new to Jira and am having some issues installing Script Runner.
Info:
I am using Jira 4.0 and am installing an older version of Script Runner. The file is named groovyrunner-1.7.13.jar. I do not have the Universal Pluggin Installer on my instance. And am following this guide to manually install the plug in:
https://confluence.atlassian.com/display/JIRA044/__installing+a+JIRA+plugin+manually?continue=https%3A%2F%2Fconfluence.atlassian.com%2Fdisplay%2FJIRA044%2F__installing%2Ba%2BJIRA%2Bplugin%2Bmanually&application=cac
After restarting, everything seems to be working fine. I can see groovyrunner in the Admin section under Plugins. It is enabled. And I can see the modules. I can even see the added functionality of being able to run scripts on post functions.
I begin to run into errors after that. It seems that the built in scripts are not available, because I cannot see them after clicking add in post function.
After reading around, I am also concerned about not being able to access the "Script Console". I want access to this to enable loging and better solve my issue.
Screenshots:
First: What I see; http://imgur.com/0YQ7M5n. Note the lack of options.
Second; What I should see (the built in functions): http://imgur.com/H9YbCMt. Note the available built in scripts.
Third: The error after clicking the add button; http://imgur.com/6WUH9La;Null pointer:(.
Thanks in advance for any help. I am sorry for breaking any posting conventions.
JamieA
July 29, 2014
You will need to look in the application log file and see what if any errors preceeded that. You can post anything relevant here...
I personally won't spend much time looking at this as your jira version is out of support.
