Script Runner(validate) check if there is a particular version defined in a multiselect custom field of versions
Brent Webster
May 23, 2013
I'm a "C/perl with C++ from 15 years ago" guy but I'm slowly picking up Java/Groovy syntax on the side so any help would be appreciated.
I reviewed Jamie's page: https://jamieechlin.atlassian.net/wiki/display/GRV/Built-In+Scripts and tried various formats:
--> cfValues['Planned For'][0] == "main"
--> cfValues['Planned For'].contains("main")
--> cfValues['Planned For']*.value.contains("main")
--> cfValues['Planned For']?.value.contains("main")
Now I tried to determine what I have:
assert cfValues['Planned For'] == "main"
| [main] false
[Customer:null, Planned For:[main], ...]
So 'Planned For' is an array but lets confirm:
assert cfValues['Planned For'].class == "main"
| [main] | false
| class java.util.ArrayList
What are the elements of the array?
assert cfValues['Planned For'][0].class == "main"
| [main] | false
| class com.atlassian.jira.project.version.VersionImpl
As suspected, I have an array of version objects that I'm trying to compare to string. How can I convert that array of version objects to strings or convert my compare string to a version object? Or what?
Brent Webster
May 27, 2013
After much head banging for checking a custom field(Planned For) of Versions
Here's my condition of a validator where
if Manager then allow
else if Planned For is null then allow
else if Planned For only equals "main" version then allow
else if Planned For only equals "trunk" version then allow
else fails
isUserMemberOfRole('Managers') || cfValues['Planned For'] == null || cfValues['Planned For']*.getName() == ["main"] || cfValues['Planned For']*.getName() == ["trunk"]
or can use the contains method if one of the multiple version is set to xxxx. i.e. "main"
cfValues['Planned For']*.getName().contains("main")
Brent Webster
May 23, 2013
Great, previewing the question really doesn't help with formatting. ;-)
Learn more
