×Hi,
I have written a custom Plugin and I am using one of its Component interface class in a groovy script outside of the plugin by using below annotation:
import com.onresolve.scriptrunner.runner.customisers.PluginModule
import com.onresolve.scriptrunner.runner.customisers.WithPlugin
@WithPlugin(<App-Key>)
@PluginModule
It ran fine inside Script Runner but when I set up the groovy as a Service, it failed and I read in some post on Atlassian forum that in such situation disable and re-enable Script runner it should work fine.
I did the same and indeed the groovy as service started functioning.
So now everytime I make any change in the Plugin code, I have to disable/re-enable Script runner.
In this context I wanted to check is this approach correct and expected that is Script runner must be disabled and enabled for a custom plugin class to be used externally or I am missing something?
Can you please advise.
Thanks.
Regards
Radha
I guess it's needed to trigger a recompiling of both classes. Did you try "making some irrelevant change like adding a space to a comment" to your service script as suggested in Script Roots section?
The situation is not exactly the same, but I feel like the solution might be the same.
