creating fields within Profields Add-on in JIra.
What scripting add-on do you want to use? And do you really mean "create custom field", or do you mean "put data in a custom field for an issue"?
HI Nic,
i'm using PROFIELDS add-on and in this add-on by default fields are available so i want to add another field into that but for this i want to write Inline script code.
can you please suggest me How to achieve this using groovy.
I'm sorry, that's confused me even more. Profields provides project fields, which you can add to. It sounds like you want to add more profields via a script. Is that right? Or do you mean you want to put data into a profield for a project with a script?
Secondly, what is the scripting add-on you want to use to do this?
Please have a look on image may be you will get clear picture what i trying to ask
and second thing they are given script console as well. Can i use this console for achieving this functionality or i need to use some another Add-on??
Right, so it's entirely within profields. I don't know it well enough I'm afraid.
ahhh...
thanks Nic ..
NIc, can we change this Project Fields view screen using CSS like
once i click on that particular tab it shows some data that data will be static.
can we do this.
I really don't know the add-on well enough to tell you.
