We are trying to build a Script Runner field which is going to return the target project while moving an issue.
It seems that such information is not in the issue context. We also know that the target project is set in an object of type com.atlassian.jira.web.action.issue.MoveIssue, but we don't know how to fetch such an object.
Do you have any idea?
There is no way to do this. By definition, Jira does not know what project you are going to move an issue to until you tell it during the move operation.
Hi Nic,
Thank you for your answer.
We do give the target project in the first screen of the Move Issue. In the next screen, we would like this scripted field help filter on values related to the target project in an AQL filter.
Does it seem feasible to you?
Yoann
A scripted field is used to present data based on existing data, they are not for asking for data during an action.
There is no way to filter on a value that you have not yet given to Jira - it needs to be told what you want to do.
Help us plant more trees
