HI,
I am searching for the scripts or the methods by which i can invoke a specific transition of an issue from the Post function of the linked issue, Let's say, From issue A-231 if i am doing "Resolve issue" then the Transition of Issue B-23 (i.e. "Submit for Approval") should execute automatically. Can that happen. I am not that into coding, please try to give as much detail as you can.
You can get the links to the issue with a script like this.
IssueLinkManager issueLinkManager = ComponentAccessor.issueLinkManager def linksOut = issueLinkManager.getOutwardLinks(issue.id) def linksIn = issueLinkManager.getInwardLinks(issue.id)
Now you must identify the correct link (by linktype and direction?), e.g. like this.
foundLinks = linksIn.findAll{it.getIssueLinkType().getName() == 'Blocker'}
and than transition the corresponding issue(s) through the IssueService (see "Transitioning an existing Issue" on https://developer.atlassian.com/display/JIRADEV/Performing+Issue+Operations).
foundLinks.each{ link -> def issue = link.getSourceObject() // ... issueService transition ... }
Be aware of using the corresponding method to get the linked issue. getSourceObject() for inward links and getDestinationObject() for outward links.
Henning
I agreed Sir, I will surely count your point.
For your requirements you will need to get into coding... there isn't off the shelf solutions for such specific requirements.
