Hello
I have, 2 months ago, implemented a Script Post-Function with Scriptrunner where I was accessing Profield plugin from Deiser.
It looks like as follow ...
import com.deiser.jira.profields.api.project.SearchService
import com.deiser.jira.profields.api.value.ValueService
import com.deiser.jira.profields.api.field.FieldService
import com.deiser.jira.profields.api.field.item.list.ListItem
import com.deiser.jira.profields.api.field.item.list.ListItemService
import com.deiser.jira.profields.api.field.textmultiple.TextMultipleField
import com.deiser.jira.profields.api.field.list.multiple.ListMultipleField
class MyClass {
@PluginModule
static FieldService fieldService
@PluginModule
static ValueService valueService
@PluginModule
static SearchService searchService
@PluginModule
static ListItemService listItemService
ListMultipleField projectModelField
def String getProjectModel (Project _project) {
String projectModel = null;
def List<ListItem> projectModelFieldItems = valueService.getValue(_project, projectModelField)
if (projectModelFieldItems.size() > 0) {
projectModel = projectModelFieldItems.iterator().next().value
return projectModel
This morning, since I had to build new process with a similar implementation, I have accessed the active workflows in order to extract the Post-Function Script as model.
And strange, the script was marked in error as described in https://community.atlassian.com/t5/Jira-questions/Script-runner-access-fields-from-Profields-plugin/qaq-p/738235
The feature was always operational, and no error was reported by our users.
I have then edited the Workflow in order to understand the root cause of errors.
Without explanation, I tried to reproduce the error in a Dev. envinronment. It was the same.
Then, since I did not have used the @WithPlugin annotation, I decided to implement it.
I begin to write the correct syntaxe it on Scriptrunnner Console.
After having elaborate the correct script, I swicth to the Scriptrunner Post-Function, and surprise, there was no more error.
I have no idea about what could be the root cause of this behaviour. It is as if a 1st usage of @WithPlugin("com.deiser.jira.profields") caused a an availability of the component in any Scriptrunner scritps, in a cache. Since the previous restart of JIRA, the component was no more avaialble until a new usage of @WithPlugin("com.deiser.jira.profields").
In doubt, I have added the @WithPlugin("com.deiser.jira.profields") ... and I will se after next JIRA restart.
Any idea ?
Thanks by advance
Vincent
Hello @Vincent Thoulé _Alkaes_, it seems that you haven't used the function @WithPlugin("com.deiser.jira.profields") in the original script. This is mandatory to access add-on functions in Script Runner.
After you added it, does it work?
Hi David,
It is exact ... I did not have used the @WithPlugin annotation in this script, but in others (RestPoint), but it worked.
The error was displayed only when accessing the source code since a long time (after different restart).
I have added the annotation just today and will see how it will evolve.
It works for the moment.
My focus is also to understand why it worked without the annotation !
V.
I see your point @Vincent Thoulé _Alkaes_, I guess is something that our friends from Adaptavist can answer much better than us.
