I need to create several subtask when I create a task, with a custom field set for each one.
I have two problems:
1.- The post function create multiple subtask doesn't work when set in firs transition. is not possible use it in that one?
2.- I use it in other transition and it works but it is not setting the custom field (single list) value (image attached)
Can you help me
Regards, Marce
