Script runner - access fields from Profields plugin
fjodors
February 27, 2018
Hello
Is it possible to accessProfields plugin's values through ScriptRunner?
For.e.g. I'd like to get profields values from custom REST endpoint.
When I am importing profields classes, it shows me an error
"Unable to resolve class com.deiser.jira........" (see attached screenshot)
Thank you in advance!
Fyodor
Adrián Plaza [DEISER]
February 27, 2018
Hi Fyodor,
It's a pleasure to hear from you again :)
You can find the solution in this post: https://scriptrunner.adaptavist.com/latest/jira/scripting-other-plugins.html
In this case, the code gets the value of the status field in a project:
import com.onresolve.scriptrunner.runner.customisers.WithPlugin
import com.deiser.jira.profields.api.field.FieldService
import com.deiser.jira.profields.api.value.ValueService
import com.deiser.jira.profields.api.field.status.StatusField
@WithPlugin("com.deiser.jira.profields")
Issue issue = ComponentAccessor.issueManager.getIssueByCurrentKey("SCRUM-7")
def valueService = ComponentAccessor.getOSGiComponentInstanceOfType(ValueService.class)
def fieldService = ComponentAccessor.getOSGiComponentInstanceOfType(FieldService.class)
def statusField = fieldService.get(9) //ID of field Status
return valueService.getValue(issue.projectObject,(StatusField) statusField)
You can find all the API info of versión 5.5.4: http://profields.javadoc.deiser.com/5.5.4/
Adrián.
fjodors
February 27, 2018
Hello Adrian
Thank you for advice.
Fyodor
Kiranped April 17, 2018
Hi Adrian,
I am using prifields api in one of my custom JIRA plugin.
I have implemented in a similar fashion as per your post bet getting below Error.
 Error Log :
java.lang.ClassNotFoundException:com.deiser.jira.profields.api.field.status.StatusField
not found by com.org.jira.plugin.synch-onejira-plugin [276]
at org.apache.felix.framework.BundleWiringImpl.findClassOrResourceByDelegation(BundleWiringImpl.java:1532)
at org.apache.felix.framework.BundleWiringImpl.access$400(BundleWiringImpl.java:75)
at org.apache.felix.framework.BundleWiringImpl$BundleClassLoader.loadClass(BundleWiringImpl.java:1955)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at com.org.jira.plugin.ojira.wf.postfunction.SetChannelFieldPostfunction.calculateChannelFieldValue(SetChannelFieldPostfunction.java:138)
April 17, 2018
Hi @Kiranped,
What version of Profields plugin do you have installed?
Adrián.
Profields 5.3.0 and jira 7.6.0
April 18, 2018
Hi @Kiranped,
Can you update Profields plugin to the last version and do the same test?
Adrián.
Kiranped June 5, 2018
@Adrián Plaza [DEISER],
I have tried with 5.6.3 version and JIRA 7.6 version. I am facing the same problem.
Profield Type: Select List (single choice)
I am using ListField
private Field getPartnerVisibleProField(){
List<Field> fields = fieldService.get();
for (Field field : fields){
if ("Field_Name".equals(field.getName())){
return field;
return null;
valueService.getValue(issue.projectObject,(ListField) getPartnerVisibleProField()) //
java.lang.NullPointerException
*********************************StatusField case******************************
if I typecast to (StatusField)getPartnerVisibleProField(), getting null object but I have a value updated
albertogb
July 27, 2018
Muy buenas Adrian,
Estoy evaluando el plugin y necesito saber si puedo cambiar un campo de tipo status en una postfuntion de script runner.
Por ejemplo:
Al ejecutar un bloqueo de una tarea que el campo status del proyecto cambie a bloqueado. ¿tienes un ejemplo para orientarme?
Un saludo.
I am evaluating the plugin and I need to know if I can change a field of type status in a postfuntion of script runner. For example: When executing a block of a task, the status field of the project changes to blocked. Do you have an example to guide me? A greeting.
Monika Agarwal December 1, 2019
@fjodors - Is this issue resolved. I am also facing the same issue.
fjodors
December 1, 2019
Hi
Yes, you need to add @WithPlugin("com.deiser.jira.profields") command, then you can use profields methods and classes.
See related issues
Hey, I have done this through REST End Point and it is working. But while I am executing same script via custom script applied on post function of the jira workflow. It shows the error.
