Script runner send custom email problem
joshO
Hello Everyone,
I seem to be having an issue trying to get my post function custom email to work. Everything appears to work fine if I preview the email through the admin settings but once I put everything in place in my workflow I recieve errors saying the property is not found.
could it be the way I wrote my code ?
if(cfValues['Comment'])
    out << "Test : ${cfValues['Comment']}"
  else
  out << "Test."
Henning Tietgens
October 23, 2013
Try the same not using GStrings ${} feature. So instead
write
"Test " + cfValues['Comment']
Henning Tietgens
October 23, 2013
Is "Comment" a custom field? If not, you should write transientVars.comment instead.
joshO
Thats Great! Thank you very much that was exactly what I was looking for.
