Script runner stop working scripts
luiz felipe zaia February 17, 2020
I have att my plugin script runner to a new version but she stop working the scripts.
1) Have any method to get the history of my older version? (in this case i wanna do a downgrade version)
2) Have a possibility if just stop working for incompatibility with my jira version?
3) If the question above is true have the possibility of jira recommend me a att with incompability?
Mihai Schwarz
February 17, 2020
Hi @luiz felipe zaia
It depends from what is the previous version of JIRA you had.
For example the script will not work if you upgraded from JIRA 6 to JIRA 7 or 8.
Provide us more details or go directly to Adaptavist support.
luiz felipe zaia February 19, 2020
hi @Mihai Schwarz
I found the solution in other forums
thx for reply my answer
