Script to count linked (several) linked issuess, per type
Mihai Mihai
We have a high level issue type called "Capability". That is the 'Parent of', via regular issue links the standard JIRA Epic issue type.
Inside epics, as issues in epics, we have stories and actions issue types. Stories and/or actions might have sub-tasks, or not (called 'Task').
When we transition a Capability to a certain status, we would like to add a comment to it that will write:
Number of Epics with a certain link in a URL field (http:\\test)
Number of stories
Number of actions
Number of tasks (the tasks have a field called TaskType - select list) . It would be great to count per task type.
Would it be possible to achieve this via a Scriptrunner postfunction?
Any code is appreciated.
Thank you!
Marc Minten (EVS)
September 9, 2019
Yes, that is easy to do.
I'll give you some examples (counting stories/tasks in Epics and counting subtasks in issues). I guess you can extend this to your requirements ? (your link names, issue type names, ... add tests on custom field, ...)
Count Stories/tasks in Epics (assume you have an Epic in variable epicIssue) :
IssueLinkManager issueLinkManager = ComponentAccessor.getIssueLinkManager()
Integer count = 0
issueLinkManager.getOutwardLinks(epicIssue.getId()).each {epicLink ->
if (epicLink.getIssueLinkType().getName() == "Epic-Story Link") {
Issue epicLinkedIssue = epicLink.getDestinationObject()
String liIssueType = epicLinkedIssue.getIssueType().getName()
if (liIssueType in ["Story", "Task"] {
count ++
 Count subtasks in issue:
Integer count = 0
issue.getSubTaskObjects().each { subIssue ->
String issueType = subIssue.getIssueType().getName()
if (issueType == "Sub-task") {
count ++
Andrew
September 9, 2019 edited
Hi @Mihai Mihai ,
My script validator check if story has link to issue type 'test' and project 'PRKEY'.
https://docs.atlassian.com/software/jira/docs/api/7.1.1/com/atlassian/jira/pageobjects/pages/viewissue/link/IssueLink.html
if (issue.issueType?.name == 'Story'){
def hasT = false
def links = issueLinkManager.getOutwardLinks(issue.getId())
if (links.find{ (it.getDestinationObject().issueType?.name == 'TestCase') && (it.getDestinationObject().getProjectObject().getKey() == 'PRKEY') }){
hasT = true
if (hasT){
return true
}else{
return false
B.R.
