Script workflow function : Current user will be added to watcher list of issue
esinclair
In JIRA v6.2.2 I am adding the post function "Script workflow function : Current user will be added to watcher list of issue" to the Create Issue transition of a sub-task.  Instead of adding the current user, the reporter of the parent ticket is added as a watcher.
1st pass - I tried the post function with no condition.  The parent reporter is added as a watcher and the current user is not.
2nd pass - I tried the post function with the example condition.  The parent reporter is added as a watcher and the current user is not.
Script workflow function : Current user will be added to watcher list of issue if this condition is true:
currentUser == issue.reporter
3rd pass - I tried it with a condition I found in a different post.  The parent reporter is added as a watcher and the current user is not.
currentUser?.name==issue.reporter?.name
Help?
