JSW/JSM DC 9.12.8/5.12.8, ScriptRunner 8.32.0
I have a UI fragment of type "Create Constrained Issue Web Item". The preview show me this:
<web-item key='request-new-analysis' name='ScriptRunner generated web item - request-new-analysis' section='operations-restore' weight='10'> <label>Request New Analysis</label> <condition class='script://jiraHelper.project?.key == "TSD" jiraHelper.project.projectCategory.id == 10001 // "Service Desk" && issue.status.id == '10101' // Waiting for Support'> <param name='£trackingParameters' value='{"scriptName":"com.onresolve.scriptrunner.canned.jira.fragments.CreateConstrainedIssueWebItem"}' /> <param name='£fragmentParameters' value='{"id":"675644f3-3e44-4826-a609-1c4c311fb5ee"}' /> </condition> <styleClass>sr-create-bound-issue request-new-analysis </styleClass> <link linkId='request-new-analysis'>https://jira-test/secure/CreateIssue.jspa?pid=10201&issuetype=10403</link> </web-item>
I have a behavior with an initialization script. Here, I test the reason of why the behavior script is called.
If, and only if, the behavior is called because the UI fragment was used, then I see 2 entries in the execution history, just milliseconds apart, even in parallel. All other ways to raise the create issue screen lead only to a single call.
In the HTTP logs I can clearly see that 2 POST requests to the URL as in the UI fragment's preview are issued.
Can anyone explain why the create issue is called twice? How can I prevent this from happening?
Thanks in advance for your replies!
Reinhard
It appears to be a SR Bug: https://assist.adaptavist.com/browse/SRJIRA-7038
To date, there is no known workaround.
Hello @Reinhard Mayr
Have you concidered the evaluation logic that "If, and only if, the behavior is called because the UI fragment"?
An extreme infinite loop such as; only create a task if a task is created in the project would create tasks forever, or realistically until an OOME occurred.
The logic may be doing something similar to the above described scenario.
@Graham Twine , thank you for your input.
I can rule out a loop, because the evaluation regarding the caller does not apply any changes. The POST request and all subsequent actions are issue twice and no further, and there is no OOME.
All I do is to check sequence of form fields and the value of behaviorContextId:
def keys = getFormContents().keySet().toArray()
if (behaviourContextId == "request-new-analysis") {
// coming from UI fragment by that name
log.warn("Create linked issue through UI fragment.")
} else if (keys.findIndexOf { it == "issueId" } < 0) {
// no issueId found: this seems to be a create screen
log.warn("create screen")
if (keys.findIndexOf { it == "summary" } < 0) {
// no summary field
log.warn("Create issue form w/o fields.")
} else if (keys.findIndexOf { it == "issuelinks" } < keys.findIndexOf { it == "summary" }) {
// issue links are before the summary
log.warn("Create linked issue form.")
} else {
log.warn("Create issue form with fields.")
} else {
// issueId is present: this is an edit, assign, or transition screen
log.warn("non-create screen")
