I am using the ScriptRunner Behaviour Initialzer on a text filed and want to populate it with a list of components that users can pick from. I am using this as a look up since I don't have access to any server side tools to create the data set.
I am using this script but the Team field doesn't get populated. The API call is valid and returns data from my browser.
getFieldByName("Team").convertToMultiSelect([
ajaxOptions: [
url : getBaseUrl() + "/rest/api/latest/project/GA/components",
query: true, // keep going back to the sever for each keystroke
// this information is passed to the server with each keystroke
data: [
currentJql : "project = GA ORDER BY component ASC",
label : "Select the Team"
// specify maximum number of issues to display, defaults to 10
// max : 5,
formatResponse: "general"
css: "max-width: 500px; width: 500px",
Ok, this is tricky.
In order to use this convertToMultiSelect method you need to respect the output that their API is expecting and none available API have this by default;
The ideia is to use a Script Rest Endpoint that will return all components from a project with the expected output format:
https://gist.github.com/ItaloQualisoni/e663e7f6da3d3893fee37cb188d4cc28
You can test the rest endpoint by accessing the below url replacing the KEY with your project key.
http://JIRAURL/rest/scriptrunner/latest/custom/getComponent?projectKey=KEY
Having the Rest Endpoint working, you will have to update your Behaviour initializer to consume our new API , see below example:
https://gist.github.com/ItaloQualisoni/29bb890f018d83ecfcdb7bb3e3c7434c
I've tested these 2 scripts with JIRA 8.6 and it worked :)
The more I learn about ScriptRunner, the more impressed I am with what I can accomplish in JIRA. I am very happy you all are part of the JIRA ecosystem.
Register now
