I installed this plugin but the console not works, keep loading and never opens. Anyone know how solve it???
Hello
I have similar issue on our test instance, is it just for console?
In our case all inline editors are not loading (workflow postfunctions, listeners etc)
Matt
This also may need some further investigation from our end.
Could you please raise a ticket in Adaptavist's Product Support portal?
Just to check, what version of ScriptRunner are you currently using?
Thank you and Kind regards,
Ram
Just updated from 6.47 to 6.50, and it didn't solve the issue. I will create account and ticket now, as it is blocking our development and i can't see any reason for it in logs or browser console.
Hi @Mateusz Muller,
Thank you for the update.
Once we receive the ticket we will review it and update you there.
Ram
@Mateusz Muller do you solved it? I'm still facing it...
@Rafael Costa I totally forgot about this issue, it was busy period back then and since it was just test environment i was forced to test on productive...
It seems to have fixed itself, but since then we have updated both jira to 8.20 and scriptrunner to 7.2.0.
This may need some further investigation from our end.
Ram
