Hi all,
I am using a groovy script in a REST endpoint, and I'd like to use the custom field to get value.
I have this block of values
def value = [
"a9d43495-9bb2-cdb0-99ea": value1,
"09fb242c-d6f2-a4a0-fea3": value2,
"60dd5447-a7c0-68fd-fb68": value3
and I have a custom field with id customfield_11601, any idea about how can I define it?
I tried this:
def issueManager = ComponentAccessor.getIssueManager()
def cField = customFieldManager.getCustomFieldObject("customfield_11601")
def cFieldValue = issue.getCustomFieldValue(cField)
def value = [
"60dd5447-a7c0-68fd-fb68": cFieldValue
but it did not work. Any help will be much appreciated.
The script is correct. Where are you using this script, on Script Console? Because if that's the case, you are not defining the issue to get the custom field. Also what errors are you getting?
When I test this script like this, it works:
def issue = issueManager.getIssueObject("DSP-2")
def cField = customFieldManager.getCustomFieldObject("customfield_11802")
def value = [
"a9d43495-9bb2-cdb0-99ea": "value1",
"09fb242c-d6f2-a4a0-fea3": "value2",
return value
Regards.
thanks for the reply.
I have created a Jira template with a few custom fields, and with ScriptRunner I have imported a groovy script as REST endpoints
And I have my key button
You are correct, I am not defining any issue, but which one should I define?
Ok, got it, if I do
def issue = issueManager.getIssueObject("INF-30")
It works, but def issue value "INF-30" is static, how can I make it progressive for the new issue?
You'll need to pass the issue key in your web item link then parse that out in your rest api.
In web item link, try /rest/scriptrunner/latest/custom/DEPLOY?key=$issue.key
Then in your DEPLOY rest API
def issueKey = queryParams.getFirst('key')
def issue = issueManager.getIssueObject(issueKey)Maybe add a bit of error trapping:
if(!issueKey){
return Response.serverError().entiy([error: "You must provide a key parameter"]).build()
if(!issue){
return Response.serverError().entiy([error: "The key provided [$issueKey] is not a valid Jira issue."]).build()
Repeating as a separate answer ... in case you'd like to mark this as the correct answer:
if(!issueKey){
if(!issue){
Hi Peter, thanks for the reply
I've configured
web item link, try /rest/scriptrunner/latest/custom/DEPLOY?key=$issue.keyand
but no luck, getting the same null value, do you know how to debug it?
Make sure your endpoint definition includes the queryParams in the call
DEPLOY(
httpMethod: "POST",
groups: ["jira-administrators","jira-users"]
) {MultivaluedMap queryParams, String body ->
And then dump some values to the log ...
log.info "queryParams = $queryParams"
log.issueKey "issueKey = $issueKey"
log.issueKey "issue = $issue"
Which of the log outputs are visible in [jira-home]/log/atlassian-jira.log should give you some hints as to what's happening.
Sorry I did not get you. This is what I have, I mean part of the code
def issue = issueManager.getIssueObject("INF-39")
def cFieldStackName = customFieldManager.getCustomFieldObject("customfield_11601")
def cFieldValueStackName = issue.getCustomFieldValue(cFieldStackName)
def cFieldVpcRange = customFieldManager.getCustomFieldObject("customfield_11602")
def cFieldValueVpcRange = issue.getCustomFieldValue(cFieldVpcRange)
def cFieldSubRange = customFieldManager.getCustomFieldObject("customfield_11603")
def cFieldValueSubRange = issue.getCustomFieldValue(cFieldSubRange)
def value = [
"a9d43495-9bb2-cdb0-99ea-066c0cc54c34": cFieldValueVpcRange,
"09fb242c-d6f2-a4a0-fea3-64b5641f8023": cFieldValueSubRange,
"60dd5447-a7c0-68fd-fb68-65aeb4025d37": cFieldValueStackName
def jsonBody = [:]
jsonBody.put("FormValues", value)
jsonBody.put("ProjectID", ProjectName )
jsonBody.put("EnvironmentId", "Environments-1")
jsonBody.put("ReleaseID", newReleaseId)
def bodyjson = JsonOutput.prettyPrint(JsonOutput.toJson(jsonBody))
def newDeployPath = "deployments"
def newDeploy = new HTTPBuilder(URL)
newDeploy.request(POST) { req ->
uri.path = newDeployPath
requestContentType = ContentType.JSON
headers.'X-Octopus-ApiKey' = 'API-xxx'
body = bodyjson
response.success = { resp, JSON ->
return JSON
response.failure = { resp ->
return "Request failed with status ${resp.status}"
2019-08-22 08:27:51,329 https-jsse-nio-443-exec-21 WARN carmine.fabrizio 507x7841x1 1qaetpz 10.100.3.55 /rest/scriptrunner/latest/custom/customadmin/com.onresolve.scriptrunner.canned.common.rest.CustomRestEndpoint [c.o.scriptrunner.runner.RestEndpointManagerImpl] Execution of REST endpoint script failed
groovy.lang.MissingPropertyException: No such property: queryParams for class: Script25
What does your rest endpoint declaration line look like?
Seems like you've cut that out of the code you shared.
