I have configured an Escalation Service with Script Runner, but the service is not executed in backgroup. In configuration, if I click on the "Run Now" button it works well, so configuration is fine, but when I save, it's not executed anymore. I found nothing in the logs.
The JQL query I'm using has another addon function ( issue in rejectedForApprovalStatus() ), but I've tried also with a simpler query and it's not working either.
I'm using JIRA 6.1.7 and Script Runner 2.1.16.
I've found another question for the same topic ( https://answers.atlassian.com/questions/9866899/script-runner-escalation-service-only-works-when-previewed ) but much older.
I've noticed that in the JIRA services page, for the com.onresolve.jira.groovy.canned.admin.EscalationService:job service, the "Properties" column is empty, while in another installation it has:
com.onresolve.jira.groovy.canned.admin.EscalationService:job com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService |
Can it cause the problem?
Any help would be very appreciated.
Hi David,
Could you change the interval to 1 ( 1 mins) and enable debug log for more details ?
May be you have Edit the services and update it thats why you are seeing Property field as blank.
Go to Manage Addon --> Disable script runner and Enable it again. It should bring back your properties fields and it may fix your issue as well.
Taha
