ScriptRunner Need to grab all subtasks of a story
Aishwarya Rajan March 23, 2018
i tried the following code but seems
ComponentManager.getInstance().getSubTaskManager(); is not supported in the jira version that Iam using and is saying that method does not exist. below is the code:
import com.onresolve.scriptrunner.runner.util.UserMessageUtil
import com.atlassian.jira.config.SubTaskManager
import com.atlassian.jira.ComponentManager
def myIssue = event.issue
if (myIssue.getIssueType().getName() == "Story"){
if(myIssue.getStatus().getName() == "In Progress"){
SubTaskManager subTaskManager = ComponentManager.getInstance().getSubTaskManager();
Collection subTasks = myIssue.getSubTaskObjects()
if (subTaskManager.subTasksEnabled && !subTasks.empty) {
subTasks.each {
any leeds reg the same???
2 accepted
3 votes
Alexey Matveev
March 23, 2018
Try like this
SubTaskManager subTaskManager = ComponentAccessor.getSubTaskManager();
subTasks.each {
yup figured it out..! thanks @Alexey Matveev
Ivan Tovbin
March 23, 2018
What is your Jira version?
If it's 7.x then to get and instance of SubTaskManager try this:
def subTaskManager = ComponentAccessor.getSubTaskManager()
yup figured it out..! thanks @Ivan Tovbin
hey @Alexey Matveev @Ivan Tovbin  i tried this..and I had to change the status of subtask to done.
subTasks.each {
if(it.getIssueType() == "Sub-task"){
WorkflowTransitionUtil workflowTransitionUtil = (WorkflowTransitionUtil) JiraUtils.loadComponent(WorkflowTransitionUtilImpl.class);
workflowTransitionUtil.setIssue(it); ---------------------------------error
String subTaskStatus = it.getStatus().getName().toString()
if(!(subTaskStatus.equals("Done"))){
workflowTransitionUtil.setAction(91);
workflowTransitionUtil.validate();
workflowTransitionUtil.progress();
it shows error in this line workflowTransitionUtil.setIssue(it);  saying cannot find matching method..any leads on this..I have done thise before in many cases but facing error in this line seems strange..
Alexey Matveev
March 23, 2018
Your code must be like this
import com.atlassian.jira.workflow.WorkflowTransitionUtil
import com.atlassian.jira.util.JiraUtils
import com.atlassian.jira.workflow.WorkflowTransitionUtilImpl
Collection<Issue> subTasks = myIssue.getSubTaskObjects()
subTasks.each {
workflowTransitionUtil.setIssue((MutableIssue) it);
the myIssue variable must be of MutableIssue type.
Aishwarya Rajan March 26, 2018
hi @Alexey Matveev  I tried using this code, but seems the getIssueType()  method is not working..is there any other alternative instead of getIssueType(). can I use getIssueType.getName()??? I need to check if the issue is a Story first and later if that Story issue has child sub task issues...any leads on this?
if (myIssue.getIssueType() == "Story"){
// UserMessageUtil.success(""+event)
subTasks.each {
Alexey Matveev
March 26, 2018
You should learn how to search the Jira Java Api. If you find the Issue class, then you will see, that issue.getIssueType returns IssueType object and that is why you are completly right you have to use
it.getIssueType().getName()
If you are not sure about any value in your script, you can use
log.error(variableName)
Learn more
