As stated in the summary, during the creation of the issue a component is set based on a list custom field and assigned to the reporter. Each component lead is a manager and I'm attempting/failing at trying to have the component lead populated to a manager field (custom user picker field). Unfortunately, I'm having a really hard time figuring out how to set a custom user picker field based on a component lead. In this situation, the list option is the same as the component's name.
import com.atlassian.jira.bc.project.component.ProjectComponent
import com.atlassian.jira.bc.project.component.ProjectComponentManager
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.customfields.option.Option
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
ProjectComponentManager componentManager = ComponentAccessor.projectComponentManager
def userCf = customFieldManager.getCustomFieldObject(10094)
CustomField selectList = customFieldManager.getCustomFieldObject(14760L)
Option selectListValue = issue.getCustomFieldValue(selectList) as Option
if (selectListValue)
String componentName = selectListValue.getValue()
ProjectComponent component = componentManager.findByComponentName(issue.projectObject.getId(), componentName)
if (component)
issue.setComponent([component])
def Lead = issue.getComponents().getAt(0)?.getLead()
issue.setCustomFieldValue(userCf, Lead)
I would really appreciate any help or anything that could point me in the right direction. Also, if there are any related issues on how to set a custom user picker field or getting a user, I would be very thankful.
I don't see anything wrong with your code.
Let me make sure I understand your intention:
So a few questions:
Since your code looked rather like pure java ... I thought you might appreciate a simplified version:
def customFieldManager = ComponentAccessor.customFieldManager
def componentManager = ComponentAccessor.projectComponentManager
def userCf = customFieldManager.getCustomFieldObject(10094L)
def selectListCf = customFieldManager.getCustomFieldObject(14760L)
def selectListValue = issue.getCustomFieldValue(selectListCf)
def component = componentManager.findByComponentName(issue.projectObject.id, selectListValue.value)
if (component)
issue.setCustomFieldValue(userCf, component.lead)
You may get some static type checking errors, but those are normal with the scriptrunner static type checker. The code should still run without issue
Hello @PD Sheehan
Your understanding of my intentions are correct and thank you for taking the time to reply to this post.
Additionally, I doubled checked to make sure the user picker id was correct and the screen/field permissions were correct.
Try to put the post function before the create the issue originally.
The scripted postfunction will still receive a "temporary" issue object (that exists just in memory). Then your script will update that object's attribute with the new custom field data and pass that the "create issue originally" which will store that updated information to the database.
@PD Sheehan , when I put the custom scriptrunner post-function in front of the "create issue originally" post-function, I received the following error.
Ok, I had to set up this test in one of my workflow with some additional log outputs ... but I figured it out.
The "component.lead" doesn't actually return a user object, so we can't apply that value directly to the custom field.
Try this instead:
if (component)
def leadUser = ComponentAccessor.userManager.getUserByName(component.lead)
issue.setCustomFieldValue(userCf, leadUser)
Thank you @PD Sheehan, that was exactly it and I was able to successfully populate a custom single user picker field with the component lead.
The custom scriptrunner post-function as the first task in the Create transition.
Option selectListValue = issue.getCustomFieldValue(selectListCf) as Option
def component = componentManager.findByComponentName(issue.projectObject.id, componentName)
if (component)
@PD Sheehan How do I copy Component lead to a custom user field? I tried using a modified version but was not able to get it to work.
I'll assume your custom field is a User Picker.
First you get the component leads from your issue (there may be more than one)
def leadKeys = issue.components*.lead
Then get an ApplicationUser representing the lead, possibly using first
if (leadKeys){
def leadUser = ComponentAccessor.userManager.getUserByKey(leadKeys[0])
or as an array if your custom field is a multi-user picker
if (leadKeys){
def leadUsers = leadKeys.collect{ ComponentAccessor.userManager.getUserByKey(it)}
Then you can just apply the user to the custom field like you would any other custom field (there are many examples on how to do that)
def cf = ComponentAccessor.customFieldManager.getCustomFieldObject(customFieldId)
issue.setCustomFieldValue(cf, leadUser)
And of course, if this is not in a postfunction (but a listener or other script), now you need to actually store the issue and index it.
Where are You put your script, as first in post function list? Try put this script as last position of post functions and add this to your script:
ApplicationUser currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser
ComponentAccessor.getIssueManager().updateIssue(currentUser, EventDispatchOptions.UPDATE_ISSUE, false)
Check syntax before you try this code.
You don't need to call updateIssue if the postFunction is before the "store the issue in the database" built-in post function. That part will do that work for you.
You only need to call this if you make the change after for some reason (maybe you need to wait until the issue is fully created such as when you want to add a watcher) or if you run this code as a listener.
@PD Sheehan & @Tomasz Bryła, since this post-function occurs in the Create transition that only contains the Create the issue originally vs the Update change history for an issue and store the issue in the database step, do I still need to update the issue due to how the post-function can not go before the creation of the issue?
