ScriptRunner: Scripted Field doesnt work
dD
Hello Community,
I want to create a ScriptedField that sums up the number values of a custom field of all linked issues. Therefore I use this code: https://library.adaptavist.com/entity/calculate-the-sum-of-all-values-of-a-custom-field-in-linked-issues.
In applied the code to my project but I receive an error message: cannot return value of type java.lang.Object on method returning type java.lang.Double
The error message arises in the last line of the code ( linkedIssues*....)
Can you help me with this?
Best thanks in advance!
// The issue type for which we want the scripted field to be displayed
final issueTypeName = 'SUD Lehrkraft Semester'
// The linked issues with that issue type will used
final linkedIssueType = 'Related'
// The values of that custom field - of type number - we want to sum up
final numberOfUsersFieldName = 'Modul SWS'
if (issue.issueType.name != issueTypeName) {
return null
log.info("IssueTypes do not match")
def linkedIssues = ComponentAccessor.issueLinkManager.getOutwardLinks(issue.id).findAll { it.destinationObject.issueType.name == linkedIssueType }
if (!linkedIssues) {
return null
log.info("No linked Issues found")
def numberOfUsersField = ComponentAccessor.customFieldManager.getCustomFieldObjects(linkedIssues.first().destinationObject).findByName(numberOfUsersFieldName)
if (!numberOfUsersField) {
log.debug "Custom field is not configured for that context"
return null
linkedIssues*.destinationObject.sum { Issue it -> it.getCustomFieldValue(numberOfUsersField) ?: 0 }
Antoine Berry
October 13, 2021 edited
Hi @dD ,
I would avise to use the custom field id instead of name, as you can have multiple custom fields with the same name (change the id with your own) :
final numberOfUsersFieldNameId = 11001
return null
return null
return null
def custField = ComponentAccessor.getCustomFieldManager().getCustomFieldObject(numberOfUsersFieldNameId)
if (!custField){
return null
log.info("Custom field does not exist")
linkedIssues*.destinationObject.sum { Issue it -> it.getCustomFieldValue(custField) ?: 0 }
Let me know if that helped.
dD
Hey @Antoine Berry , best thanks for your help!
I tried your code but it doesnt made a change, then I got a little confused so I changed it back. Also I checked the CustomFields and there is no other Field with the same name.
But I also progressed, as I could fix some errors. Now I receive Logs, which may help to understand the soruce of the problem. But I dont understand it. Maybe you can think of an soulution :) Anyway best thanks to you!!
here also my revised code:
final linkedIssueType = 'SUD Modul'
final numberOfSWSFieldName = 'Modul SWS'
return null
def linkedIssues = ComponentAccessor.issueLinkManager.getInwardLinks(issue.id).findAll { it.sourceObject.issueType.name == linkedIssueType }
return null
def numberOfSWSField = ComponentAccessor.customFieldManager.getCustomFieldObjects(linkedIssues.first().sourceObject).findByName(numberOfSWSFieldName)
if (!numberOfSWSField) {
return null
log.info("configure cf worked")
linkedIssues*.sourceObject.sum { Issue it -> it.getCustomFieldValue(numberOfSWSField) ?: 0
log.info(it.getCustomFieldValue(numberOfSWSField))
Antoine Berry
Hi @dD ,
The correct method to retrieve a custom field value is with the id and not the name of it (as you can see in the javadoc the getCustomFieldValue method does not accepet a String).
Could you please try my code and add a screenshot of the error you are getting please.
dD
Hey @Antoine Berry  you are right, it is best to use IDs.
Fortunately I have found a new script that works semi. By semi I mean: It gives me an error but also the correct answer. It sums up all linked issues which works fine.
I changed the method from name to id, like you advised me. It feels better, still I receive an error.
import org.apache.log4j.Logger
import org.apache.log4j.Level
import com.onresolve.scriptrunner.runner.customisers.PluginModule
import com.atlassian.jira.issue.link.IssueLinkManager
import com.atlassian.jira.issue.CustomFieldManager
@PluginModule
IssueLinkManager issueLinkManager
@PluginModule
CustomFieldManager customFieldManager
// You must change the following variables as your needs
final numericFieldNameId = 10301
//Retrieve customfields from the system
def custField = customFieldManager.getCustomFieldObject(numericFieldNameId)
// Ensure source fields really exist
if(custField)
// Look for all linked issues
def inwardLinkedIssues = issueLinkManager.getInwardLinks(issue.id)*.sourceObject
def outwardLinkedIssues = issueLinkManager.getOutwardLinks(issue.id)*.destinationObject
def linkedIssues = inwardLinkedIssues + outwardLinkedIssues
return linkedIssues.sum{ Issue linkedIssue -> linkedIssue.getCustomFieldValue(custField) ?: 0 }
 My error message is here:
Antoine Berry
The error is because the script cannot check the type of the custom field value, but in this case it should return a double if your field is a number. It should still execute if you try it as the error will be corrected on execution time.
Your new script follows the same logic (and uses the custom field id). It also retrieves both issue link types.
Like • dD likes this
