ScriptRunner Scripted Field : re-index issue
Marc Minten (EVS)
January 29, 2018
I want to reindex issues with scripted fields, and implemented the example as described in the Scriptrunner documentation (under "JQL Searches in Script Fields").
When running the code, I get an error
2018-01-26 16:42:04,550 ajp-nio-8009-exec-17 ERROR MMN 1002x4544387x4 1tgasxs 10.129.0.102 /rest/api/2/version/17327 [c.o.scriptrunner.runner.AbstractScriptListener] Script function failed on event: com.atlassian.jira.event.project.VersionReleaseEvent, file: EVSListeners\PLMConfigListener.groovy
groovy.lang.GroovyRuntimeException: Could not find matching constructor for: com.atlassian.jira.jql.query.IssueIdCollector(org.apache.lucene.index.ReadOnlyDirectoryReader)
 This example worked in the past, but recently we did an upgrade from Jira 7.1.7 to 7.4.3 and Scriptrunner from 4.3.15 to 5.2.2. Do not know if there is a relation...
Stephen Cheesley _Adaptavist_
January 29, 2018
Hi Marc,
The constructor that takes an argument was removed in Jira 7.3.3. You can fix your script by changing line 53 to:
def issueIdCollector = new IssueIdCollector()
Effectively if you remove the parameter the new version of the collector should work as expected.
I hope this helps!
Marc Minten (EVS)
January 30, 2018
Hi, thanks for your quick help.
Indeed, this solves my issue!
Manuel
Same issue with the latest script on the adaptavist website and this fix here isn't working. Any idea?
