Hi community, looking for some assistance on this one.
Using Scriptrunner Behaviors, when a user selects an option in custom list called "Category" I would like to set an existing value in my custom list field "Group". I'm able to retrieve the Category values without an issue, however I cannot set the Group select list value (by name or by option ID). Can someone please assist in how to set this select list value?
Here is the script:
import com.onresolve.jira.groovy.user.FieldBehaviours
import com.onresolve.jira.groovy.user.FormField
import com.atlassian.jira.issue.CustomFieldManager
// Define both custom select lists
def category = getFieldByName("Category")
def group = getFieldByName("Group")
// Get the Value of the Category field and Group field
def catval = category.getValue()
log.warn("Category Value: " + catval)
def groupval = group.getValue()
log.warn("Group Value: " + groupval)
// If the Category select list value equals Other
if (catval == "Other"){
// Set the value of the select list to Group option id of 12208 "Test Group"
group.setFormValue(12208)
After some research, I was able to resolve this issue. Hope this helps others!
import com.atlassian.jira.issue.IssueManager
def issueManager = ComponentAccessor.getIssueManager()
def customFieldManager = ComponentAccessor.getCustomFieldManager();
def authContext = ComponentAccessor.getJiraAuthenticationContext();
def optionsManager = ComponentAccessor.getOptionsManager()
CustomField category = customFieldManager.getCustomFieldObjects(issue).find {it.name == "Category"}
CustomField group = customFieldManager.getCustomFieldObjects(issue).find {it.name == "Group"}
fieldConfig = group.getRelevantConfig(issue)
group1 = optionsManager.getOptions(fieldConfig)?.find{it.value == "Group Name 1"}
group2 = optionsManager.getOptions(fieldConfig)?.find{it.value == "Group Name 2"}
groupother = optionsManager.getOptions(fieldConfig)?.find{it.value == "Unassigned"}
categoryvalue = issue.getCustomFieldValue(category).getValue()
log.debug("Category: $categoryvalue")
//If CustomField 'Category' matches the following values...
if (categoryvalue == "ValueA" || categoryvalue == "ValueB" || categoryvalue == "ValueC" ){
//Set CustomField 'Group' to "Group Name 1"
issue.setCustomFieldValue(group, group1)
log.debug("Group: $group")
if (categoryvalue == "ValueD" || categoryvalue == "ValueE" || categoryvalue == "ValueF" ){
//Set CustomField 'Group' to "Group Name 2"
issue.setCustomFieldValue(group, group2)
//If CustomField 'Category' matches the following value...
else if (categorycatvalue == "Other" ){
//Set CustomField 'Group' to "Unassigned"
issue.setCustomFieldValue(group, groupother)
