ScriptRunner Syntax Reference
Fabio Rodrigues July 21, 2017
Is there any documentation that explains how to write scripts with "ScriptRunner" plugin? A reference with classes, functions, etc?
2 accepted
Gaston Valente
July 21, 2017
This plugin has great documentation:
https://scriptrunner.adaptavist.com/latest/index.html
Code examples:
There're a lot
https://scriptrunner.adaptavist.com/latest/jira/recipes/workflow/postfunctions/set-issue-attributes.html
Jira API Doc: most of the code you will write is based on the jira api:
https://docs.atlassian.com/jira/server/
Start by looking at this particular class, all begins here:
https://docs.atlassian.com/jira/latest/com/atlassian/jira/component/ComponentAccessor.html
Steven Behnke
July 21, 2017
Scriptrunner uses the Atlassian JAVA APIs. You're probably best off reading the javadocs.
