×Hello,
I’m using Jira Data Center (v9.15.2) and attempting to run the basic ScriptRunner examples provided under "Example Scripts," specifically the "Show Web Panel" script highlighted in yellow. However, the script doesn’t seem to compile and consistently displays "Checking script" at the bottom right.
The current ScriptRunner version I’m using is 8.34.0.
Could anyone let me know if they’ve encountered this issue?
Thank you!
Hi @KL Kumar
Could you provide a full screenshot of your Fragment configuration? This is to double-check if the correct fragment is being used.
Thank you and Kind regards,
Ram
Hi @Ram Kumar Aravindakshan _Adaptavist_ ,
Here's the complete screenshot for the example I'm trying out from Display a dialog box info on login (showcase example in ACE KL May/2022) - ScriptRunner - Adaptavist Library Community
Best Regards,
Kumar Kodati
That's odd. Do any other of the example scripts or other parts of ScriptRunner work for you?
Hello Matt,
The issue seems to be when using the HTML and/or JavaScript examples in ScriptRunner. The other Groovy scripts seems okay.
Tried the below, but no luck yet!
