×I'm trying to set up a post-function that creates sub-tasks when the component is something specific. I'm finding some examples of figuring out the project lead etc but not component name itself. Anyone have anything working they could share? :)
The goal would be to add this to the create -step. I was going along the lines of...
def components = issue.getComponents()
cfValues['Task Type']?.value == 'Definition' && issue.projectObject.key in ["TEST"] && components.contains('W_Migration')
But this obviously doesn't work. It validates in ScriptRunner but nothing happens in transition (either in create or anywhere else).
Any assistance is greatly appreciated :)
Awesome! Thank you. I tried a similar one before but without the '?'. Maybe something else was different as well. In any case, this worked.
Thanks you guys!!
Hi everyone, I have been trying to figure out how to do this for about 2 weeks and had nearly given up hope but I just found that this solution works for me. Thanks so much!
