ScriptRunner post-function: Auto create Subtask, conditions help
Timothy Ryner
June 24, 2019 edited
I am trying use Scriptrunner's "Create a sub-task" post-function to automatically create a subtask on a particular transition when number custom field (named "# Maps") has a value above 25.  We'd like to create a subtask for checking maps when the parent issue indicates there are a lot of maps.
I can't figure out the syntax for the post-function's condition.  Below is basically what I need, but of course, the ">=" isn't valid.
cfValues['# Maps'] >= '25'
Jira Server v7.9.2
ScriptRunner v5.4.12
Any ideas?  Thanks in advance!
Payne
Even though your custom field is numeric, perhaps the cfValues[] array treats all custom fields as strings. Try casting to an int, i.e.
(int)cfValues['# Maps'] >= 25
Timothy Ryner
Gave it a quick test, and that appears to have done the trick!
Much obliged!
Like Payne likes this
Let's build A Rovo Agent 🤖
Save your spot
