I'm looking for a script that removes all inactive users from any groups they are in. Does anyone have such a thing?
thanks in advance
Chris
For anyone who searches this, this is what I did in the end - including some logging and the ability to exclude groups that are controlled via ldap:
import com.atlassian.jira.security.groups.GroupManager
import com.atlassian.jira.user.util.UserManager
import com.atlassian.jira.user.util.UserUtil
import org.apache.log4j.Logger
import org.apache.log4j.Level
def log = Logger.getLogger("com.jira.DelActiveScript")
log.setLevel(Level.DEBUG)
def userManager = ComponentAccessor.getUserManager()
def userUtil = ComponentAccessor.userUtil
def users = userManager.getAllApplicationUsers()
def array = users.toArray()
def groupManager = ComponentAccessor.getGroupManager()
for (int i =0; i < array.size(); i ++){
def user = array[i].getName().toString()
if(!userManager.getUserByName(user).isActive()){
def groups = groupManager.getGroupsForUser(user)
for (int j =0; j < groups.size(); j ++){
if(groups[j].getName().toString() != "jira-users"){
def groupName = groups[j].getName().toString()
log.debug(user + " - " + groupName)
def group = groupManager.getGroup(groupName)
userUtil.removeUserFromGroup(group, userManager.getUserByName(user))
Thanks for this. Still works well!
@Chris Shepherd I am looking to remove Inactive users from all my groups, including jira-users. I think this is what you were trying to achieve. Can you help me understand what is happening in this portion of your script above?
I am not strong with scripting (obviously). Thank you.
Well, it's 5 years since I wrote it but:
is creating a counter (j) to loop through all the groups
Get the group name for the counter.
If the group name is not equal (!=) to jira-users then do the next bit
get the group name (again! who wrote this rubbish :) )
write it to the log file to show whats going on
Then take them out the group.
I ignore the jira-users group as that is controlled by ldap in our instance. but if you don't want to do that remove the
HTH
Chris
Tried running this and removed
Result shows "null"
The Log is packed full of entries identifying the Inactive User and group assignment, then the INFO message"[IssueSecurityLevelManagerImpl.projectAndUserToSecurityLevelCache]: Cache com.atlassian.jira.issue.security.IssueSecurityLevel managerImpl.projectAndUserToSecurityLevelCache was flushed
When I go back to the User Management area though, all the Inactive users are still assigned to all their groups, though. Any guidance if appreciated.
Sorry don't really know why that wouldn't work. you could try adding some more logging:
change
to
def userObj = userManager.getUserByName(user)
log.debug(group)
log.debug(userObj)
userUtil.removeUserFromGroup(group, userObj)
If either group or userobj display as null then that might be the problem.
Ive used deprecated method in it, but it should work i think.
{code}
def iter = array[i].getName().toString()
print iter
def groups = groupManager.getGroupsForUser(iter)
def currentApplicationUser = userManager.getUserByName(iter)
print currentApplicationUser
if(!userManager.getUserByName(iter).isActive()){
userUtil.removeUserFromGroups(groups, currentApplicationUser)
{code}
Thanks so much, it wasn't exactly what I needed but got me right to the edge of what was required.
Thanks Loads
Thanks for this, I faced a similar req, but removing just from a specific group since we synch groups from LDAP, here's my modified version, saved it in ScriptEditor, and used it with different group names as separate ScriptRunner Jobs:
Thanks for that @efrel !
I have tried using this and see some warnings appear in ScriptEditor.
The first is concerning line 17 and the variable "log":
If I change that to "logs" another warning appears, this time on line 27, concerning an improved search method:
Do you have any tips on how to deal with this?
Can it safely be ignored, or could you improve it, maybe?
Many thanks and kind regards.
Michiel
Hi Michiel, apparently there are newer more efficient ways to accomplish this now, I upgraded my code as well and tested successfully on 8.22.6, here it is:
Does anyone know how to do this for Jira Cloud using ScriptRunner?
