I'm trying to write a scriptrunner post function script to transition a linked issue in another project. I've used pieces from the Auto Close Subtasks and All Depending Issues Resolved examples to come up with my code.
When the post function runs, the user sees an error "Property 'destIssue' not found" in the transition screen and can't proceed. Had a look at the API docs and I seem to be doing everything correctly.
This is my first groovy script, so I'm sure I've done something wrong, but don't know where.
I was also wondering about the ScriptRunner's example code use of directly accessing values such as "issue.id" and "it.statusObject.name" instead of using accessor methods to get these values. Is this proper or just old styling?
Running JIRA 6.3.13.
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.link.IssueLink def issueService = ComponentAccessor.getIssueService() def linkType = ["escalated from"] def user = ComponentAccessor.getJiraAuthenticationContext().getUser() def linkMgr = ComponentAccessor.getIssueLinkManager() for (IssueLink link in linkMgr.getOutwardLinks(issue.id)) { if (linkType.contains(link.issueLinkType.name)) { def destIssue = link.getDestinationObject() def destStatusObject = destIssue.getStatusObject() if (destStatusObject.name == "Installing") { def issueInputParameters = issueService.newIssueInputParameters() issueInputParameters.with { setComment("Camera has been installed. Signs are needed before camera can be activated.") setSkipScreenCheck(true) } def validationResult = issueService.validateTransition(user, destIssue.id, 41, issueInputParameters) if (validationResult.isValid()) { def issueResult = issueService.transition(user, validationResult) if (! issueResult.isValid()) { log.warn("Failed to transition task ${destIssue.key}, errors: ${issueResult.errorCollection}") } } else { log.warn("Could not transition task ${destIssue.key}, errors: ${validationResult.errorCollection}") } } } }
Community moderators have prevented the ability to post new answers.
It's proper, it's the groovy way... I did a quick google and found this which sums it up quite nicely:
The problem you are having is an old-ish issue with inline scripts, and the fact that the JIRA tries to expand strings like $destIssue before it passes the parameters to the workflow functions.
You could upgrade and fix it, except we don't support 6.3 anymore. So the easiest option is to move the inline script to a file, and that should fix it. Other than that your script looks ok...
Thanks Jamie. This took care of the error. We will be upgrading JIRA sometime in December/January.
For anyone else looking for how to transition a linked issue, here's my current script (JIRA 6.3.13):
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.link.IssueLink def issueService = ComponentAccessor.getIssueService() def linkType = ["Escalated"] // 6.x validateTransition wants a User, so we have to use getDirectoryUser() // 7.x validateTransition wants an ApplicationUser, so remove the .getDirectoryUser() after we upgrade def user = ComponentAccessor.getJiraAuthenticationContext().getUser().getDirectoryUser() def linkMgr = ComponentAccessor.getIssueLinkManager() // Look through the outward links for (IssueLink link in linkMgr.getOutwardLinks(issue.id)) { def destIssue = link.getDestinationObject() // Does the name of the link match "Escalated" ? if (linkType.contains(link.issueLinkType.name)) { def destStatusObject = destIssue.getStatusObject() // Is the status of the linked issue "Installing" ? if (destStatusObject.name == "Installing") { // Prepare our input for the transition def issueInputParameters = issueService.newIssueInputParameters() issueInputParameters.with { setComment("Camera has been installed. Signs are needed before camera can be activated.") setSkipScreenCheck(true) } // Validate transitioning the linked issue to "Signs Needed" def validationResult = issueService.validateTransition(user, destIssue.id, 41, issueInputParameters) if (validationResult.isValid()) { // Perform the transition def issueResult = issueService.transition(user, validationResult) if (! issueResult.isValid()) { log.warn("Failed to transition task ${destIssue.key}, errors: ${issueResult.errorCollection}") } } else { log.warn("Could not transition task ${destIssue.key}, errors: ${validationResult.errorCollection}") } } else { log.warn("Skipping link: ${link.issueLinkType.name} ${destIssue.key} ${destStatusObject.name} (wrong status)") } } else { log.warn("Skipping link: ${link.issueLinkType.name} ${destIssue.key} (wrong type)") } }
cool, looks proper...
One more question about this script. Is it possible for the transition on the linked issue to be performed by a different user. The logged in user may not have permission to transition the linked issue, but I have a user "jirabot" which has permission to run any transition in any project. Could I specify a different user in the issueService.validateTransition call? How would I do this?
Found my own answer after some trial and error. Changed this line:
//def user = ComponentAccessor.getJiraAuthenticationContext().getUser().getDirectoryUser() def user = ComponentAccessor.getUserManager().getUserByName("jirabot").getDirectoryUser()
I found that I also needed to remove:
Otherwise the linked issue would get the comment twice (once from the logged in user and once from the jirabot user).
Hello i did the same code in a post function , an error always appear , please can somone help me !!!
My code:
def linkType = ["Cloners"]
// Does the name of the link match "Cloner" ?
// Is the status of the linked issue "En attente niveau 2" ?
if (destStatusObject.name == "En attente niveau 2") {
// return destStatusObject.name
//return destIssue.id
// return user
def validationResult = issueService.validateTransition(user, destIssue.id, 31, issueInputParameters)
return validationResult
} else {
} else {
} else {
error:
V2018-10-27 20:13:12,919 ERROR [runner.ScriptFieldPreviewRunner]: ************************************************************************************* 2018-10-27 20:13:12,919 ERROR [runner.ScriptFieldPreviewRunner]: Script field preview failed for field that has not yet been created groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.bc.issue.DefaultIssueService.validateTransition() is applicable for argument types: (com.atlassian.jira.user.BridgedDirectoryUser, java.lang.Long, java.lang.Integer, com.atlassian.jira.issue.IssueInputParametersImpl) values: [kimo:1, 10459, 31, com.atlassian.jira.issue.IssueInputParametersImpl@1eed919] Possible solutions: validateTransition(com.atlassian.jira.user.ApplicationUser, java.lang.Long, int, com.atlassian.jira.issue.IssueInputParameters), validateTransition(com.atlassian.jira.user.ApplicationUser, java.lang.Long, int, com.atlassian.jira.issue.IssueInputParameters, com.atlassian.jira.workflow.TransitionOptions) at Script1273.run(Script1273.groovy:31)
can some one help me in this topic please!!
I'm also wondering if this script will work for remote issue ( remote JIRA instance)
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
